Auto initializing very annoying
I strongly suggest that you add some buttons to control the initializing and preview generation. But having it done automatically, the software doesnt allow one to choose the parameters one wants before it try to get started. the result is that the controls are super sluggish.
You can find the option to Configure your Autopilot settings in the Preferences > Autopilot options
