Looking through the logs, the only crash or error I see is from awhile back when running the aion model with stabilization and it looks to be an issue with the video size and the depreciated pixel format. Did you only see this error when running aion?
No, that this didn’t involve anything but a crop and enhancement. First crash went to the Apple crash reporter when attempting to preview 1 second. Then on the second try, the auto crop stabilization moved the video off screen. I was working with a image sequence.
Hi, I got another crash this morning with the report only going to Apple. I am only using 1 max processes. My system uses High Power when plugged in and low power when on battery. Here is the summary that I copied for the Apple Report:
Translated Report (Full Report Below)
Process: Topaz Video AI [61761]
Path: /Applications/Topaz Video AI.app/Contents/MacOS/Topaz Video AI
Identifier: com.topazlabs.Topaz-Video-AI
Version: 5.0.3 (5.0.3)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
VM Region Info: 0x60 is not in any region. Bytes before following region: 4363747232
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 104198000-1043c4000 [ 2224K] r-x/r-x SM=COW /Applications/Topaz Video AI.app/Contents/MacOS/Topaz Video AI
