For next Topaz AI releases please consider that copy funcion should copy all soundtracks build in orginal video, not one only, especially that all subtitles are copied into new file.
Which container and codec are you having set for the export?
MKV (H265, Main10, CBR 180).
Can you send the logs from these processes to the support team for review? help@topazlabs.com
