Audio does not transfer to output video
when outputting a video file no audio comes with it in any format.
DxDiag.txt (177.0 KB)
software does not identify any errors on file completion
thanks
Hi Andrew,
Could I take a look at the app’s log files to see what is causing the error in Video AI?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport.tar.gz” file to your reply.
