As LR plugin, Topaz ai not recognizing Sony .ARW files after update
If I try to open topaz ai from LR, a dialogue box appears upon opening that says “(filename.ARW) not supported, or not a RAW file”. I am still able to edit through photoshop. This happened randomly, it used to work fine. Anyone else had this issue? This is with my Sony a7rV. Thanks much.
Can you check there are no special characters in your image file name or the folder name?
What compression are you using for your ARW files? From the Supported Cameras article:
