In processing, Startlight Mini is creating a feature on my dog that does not exist. It does not occur on every frame.
logsForSupport.zip (1.9 MB)
You’re on the alpha model with xray vision by the looks of it.
Thank you for sharing the screenshot and the logs. The team is looking into another users report of a similar issue. Did you run this video through using Hyperion first and convert the video color space to HDR?
Are you able to share the source file for our team to look into and try and replicate the issue?
Kyle, Thanks for following up. I upload the file under Dog Artifact. Yes I did a run with as you surmised to improve the interlace issues before I ran starlight.
