Artefacts resulted from sharpening
Before photo AI
After photo AI - latest version
You can do two things: either lower the sharpening strength or select the insect as the Subject which will then restrict the sharpening to the subject.
Can you take a screenshot of your settings while using Topaz Photo AI? Just as @AiDon has suggested you may have the sharpening strength too high.
