Here’s how it works now:
- First, you add the modules you need to one image—upscale, sharpening, etc.
- Then, you select all the other images, right-click, choose “Apply,” and select “Current Settings” to copy the settings from the selected image to the others.
However, you can only do this if you add or remove a module, not if you change the settings within a module.
For example, if you change the upscale scale for one image and the other selected images have the upscale module but with a different scale, you can’t use “Current Settings” to apply it across all images. It’s deactivated.
Here’s my workaround:
Say I have 10 images, and I’ve already applied the same settings to all of them. I select the second image in the list, remove one of the modules, then select all the images again, and “Apply” the current settings from the first image to all of them. This re-enables the option to apply the settings across all selected images.
In my opinion, the Apply > Current Settings should never be deactivated. Even if we don’t change anything. So then it will work 100% of the time.
