Apollo Frame Interpolation Fails to Start (Stuck at 'Initiating process... 98.88%')
Trying to frame interpolate a video with an unusually low framerate using Apollo model [15fps → 60fps], it gets permanently stuck at "Initiating process… 98.88%’ and will not progress. I’m also using scene splitting, if that matters.
logsForSupport.zip (1.4 MB)
DxDiag.txt (174.1 KB)
Thanks for reporting this. Can you clear it and try running it through again?
I have tried multiple times, it gets stuck at the same point.
I have same issue , did you solve it ?
