Anyway to avoid loss of detail in MOTION interpolation models?
There’s a clear loss of fine detail when running any of the motion models on good quality movies to get higher fps(no slow mo). You can see obvious loss of detail in background textures and faces. It has a denoising effect.
You can also see an obvious big loss of grain as well as loss of fine detail in movies that don’t have much grain.
Anyway to avoid this? (I’ve settled on using apollo to go to 100fps as the best overall, since apollo doesn’t look good at 2x fps and chronos has too many artifacts) But this loss of fine detail makes my movies a little worse looking as far as detail goes. Background a bit more blurry and entire image softer. All motion models do this.
A tv with a relatively weak processor(a 4080 is probably 50 to 100 times as powerful) that has to do all kinds of extra image processing (like controlling dimming zones) can manage to interpolate and not lose any obvious image quality while doing the entire thing live on the fly! So no excuse for topaz.
Flowframes(Rife) also causes loss of fine detail. Stick a grainy movie in topaz and see. It’s also noticeable on movies with NO grain. Details are lost in the face and things become more blurry.
Also, a good tv with good motion interpolation can interpolate to uneven amounts like 24 to 30fps with even cadence and no extra stutters. Topaz has massive amounts of stutters and creates a vfr with wildly uneven cadence when not using a 2x or 4x multiplier. Future updates with Uneven common fps conversions would also be benefitical so we are not stuck at just 2x or 4x fps increase on topaz.
Fixing these two things would be awesome and make it even better in the future. Adding grain after the interpolation trying to mask a loss of detail is not a solution.
100fps is a pretty aggressive target, and the more frames a model has to generate, the more that softening compounds. Realistically, human vision can’t perceive motion smoothness gains much past 60fps anyway, so you’re likely paying the detail cost of 100fps without getting a visible benefit over something like 48 or 60fps. Worth testing a lower target, you may get cleaner results with motion that looks just as smooth to the eye.
Do you also lose fine details on the non-interpolated frames? If the source is, for example, 30 FPS and you set the output to 60 FPS, roughly every second frame is interpolated, sure there will be some loss on the interpolated frames, but the others shouldn’t be affected, or the model is doing something wrong..and output codec matters, H.264/H.265 removes some grain.
“Realistically, human vision can’t perceive motion smoothness gains much past 60fps anyway”
Sorry, but that’s simply wrong(No disrespect) I do agree 48fps is fine for movies assuming your tv can match that frame rate properly, but apollo below 4x fps is jittery as hell and chronos at 2x looks great, but has way too many artifacts to be useable. That’s the only reason I used 100fps(4x25). (My tv can do 50/100hz, but not 48)
Try gaming at 120fps and then gaming at 60fps. Do a medium speed pan in hunter call of the wild or really any game. You’ll notice a lack of blur at 120fps compared to 60fps. It’s not comparable. If you couldn’t perceive motion gains past 60fps on lcd/oled then you would never game at 120fps and there’d be no reason for 120hz or higher tvs.
Also, this loss of detail happens at 48fps. Your tech department is well aware. Ask them.
Take ANY grainy movie and look at the obvious loss of grain after running any motion interpolation model. It’s literally a denoiser! And if you look at faces in movies without grain there is a loss of detail in some scenes. Background texures are reduced ect.
Hi Mayday,
Take a moderately grainy movie and run the models on it and check it. Do it yourself in a couple of scenes. You’d have to be blind not to see it. The output codec doesn’t matter. We are talking about a significant loss of grain. I’m not a fan of grain, but it’s also obviously removing fine details in movies even without grain. It’s actually a good denoiser if you’re looking to do that! Better than handbrake’s filters at removing noise/grain. It removes more grain than that filter actually and retains more sharpness. lol
It’s all frames at least in motion in normal watching. I’m not stopping looking at each individual frame.
ok i check this myself. We have to look at the individual frames what it does.. I already knew that frame interpolation does some denoise, the interpolated frames are often more blurry than the origs, especially during motion. However, the original frames that the model does not touch must not suffer any quality degradation.
If you convert 25 FPS to 100 FPS, then naturally 3 out of every 4 frames are interpolated. That’s exactly why I don’t use such high frame rates.
