thanks. is there a way to override the file name? other plugins add the function to the name (giga, sharpen, etc). i’d like to see this in denoise also, or at least the ability to override if i want to.
I have moved it to a Product Feature Request … don’t forget to vote. Remember though, GigaPixel doesn’t run as a Plugin so it isn’t relevant to what you are asking and Sharpen AI doesn’t allow Save as in Plugin mode.
DeNoise AI, as the others allow Save as in standalone mode from the file menu and you can specify the name of the File to be saved:
thank you!
noted and voted!!!
