I have a $19k Mac Pro with two interconnected GPUs…one of which is never used by TVAI…
Have you guys not figured out how to use both yet? Or at least…run two jobs at the same time…one using one GPU and the second using the other? I’ve got it on “auto” and GPU never goes above 50%…so…
It doesn’t seem like this should be hard to implement at the very least for two separate jobs running at the same time.
This is pretty interesting that it doesn’t work. It’s even more interesting that no one from Topaz responded to you about it. I used 2 1080ti’s with TVAI in Windows for 2 years until I had a coolant leak ruin them. I picked up a 4070 and I’m trying to get along with the Linux beta as I can’t stand Windows and now’s the time to convert this machine. I was thinking about picking up a 2nd 4070, but I’m not really sure that’s a good idea until these guys fix the issues with the Linux version, I don’t even know that 2 GPUs will work in Linux.
As a paying customer Topaz should be giving you an answer regarding this. I’m not concerned with the Mac version myself but they need to stop making crazy UI changes that break everything and focus on getting the program running right so people get what they paid for. All I can say is the Windows version works with 2 of the same Nvidia GPUs in SLI up til version 3.2.x at least.
Yeah last thing I heard was that it didn’t work on Mac OS, and they were working on it, then nothing. Dunno!
