Please allow deletion of default presets from within the gui or at least do not run a repair install after manual deletion of the json files. I have no use for all those presets. They only do clutter up my list of custom presets.
Pretty sure you can already do this, if you are on Windows, just delete them from C:\ProgramData\Topaz Labs LLC\Topaz Video AI\presets
If you are on Mac OS, I can’t help with that.
I did this, but when i started the app after this the repair installation of the msi installer was running.
You are correct, I was able to reproduce this as well.
So Topaz needs to remove the bundled presets from the ‘protected’ installation files so they can be deleted by the user, or give the option to skip installing the presets altogether on initial installation.
You can vote once on your post BTW to get it some traction.
