i miss the old way of finding out what worked you could see side by side/
i also wish you had the option to pick the operation order like denoise sharpen anti shake and that if we could pick the order there are some limitations that would be expanded on how well the software does
im having a problem with it making some clear parts blurry when using the revert compression
For best practices, please vote for 4 way comparison view and edit the name of this submission to reflect the second point in your post please.
I will vote for this.
I have tested interpolation and upscaling 160p-15fps to 960p-30fps and it looks like that in this order I’m getting small flickering.
So I would like to change the order to do at first upscaling and afterwards interpolate.
In this order I’m geting much better results.
I have used Iris and Apollo in this example.
EDIT:
I’m using TVAI 3.4.0 at the moment.
If I use Chronos instead of Apollo, the difference is not as big.
