All attempts at enhancement cause "Resolution Error"
  2. Your system profile
logsForSupport.zip (50.8 KB)
Hello,
From the logs, it looks like you’ll need to install the latest Studio driver for the GTX 1070:
Driver does not support the required nvenc API version. Required: 12.0 Found: 11.0
[h264_nvenc @ 000001AC56545FC0] The minimum required Nvidia driver for nvenc is 522.25 or newer
I have the same error. I have a Lenovo P15s Gen1 with an Intel UHD 10th Gen. (31.0.101.2125) and Nvidia Quadro 920 M (Nvidia Driver 545.84) under Windows 11. Not the latest and greatest for AI-Rendering but for testing purposes enough.
To specify this. Switched back to P520-Rendering only. GPU-workload maxed out, which is ok. Then a Driver error instead of Resolution error was coming up.
"- Try changing the output resolution, bitrate or encoder.
  • Please update Nvidia Driver. The minimum required …522.25 or newer."
Thanks, Tony. The driver fixed the error.
I see, though that Video AI does not allow adjustment of color, which makes it unsuitable for underwater videos.
