Ai2 .0.0 must slower in processing as AI1
@driesbeetge27 Please upload your system information so I can check the hardware is up to date. System Requirements | Topaz Photo AI
HI THANKS
macOS Monterey version 12.6.9
iMac(Retina 5K,27-1nch late 2015
processor 3.3GHz Quad-core intel core i5
memory 32GB 1600 MHz ddr3
start Disk SSD
Graphics AMD Radeon R9 M395 2gb
TOPAZ PHOTO AI
TOPAZ LAB 2023 RELEASE
VERSION 2.0.0
THANKS
It looks up to date so I suspect there may be missing model files. Please follow the steps below to fix this.
In MacOS System Settings > Privacy & Security > Files & Folders, find Installer and enable all locations for it.
Run the Topaz Photo AI installer. You can download a new installer from the downloads page directly. https://topazlabs.com/downloads/
HI Thanks for the quick response, Follow your instructions and download the new Topaz installer
With new data, the processing process is still very slow
Will try ones more from RAW as well as Tiff files
Keep you updated
