AI Not saving Images to LRC
Hi I’ve just updated to V 1.4.0 and every time I send an image from LRC to Topaz Photo AI I can see it work on it but when I try to save it back tit goes glacial then stops with this message.
I’m using Windows 11 Topaz AI V1.4.0
Error could not run model.
Does this every time I use the preserve text mode if I disable this is seems to work and saves as per usual.
I’ve been using previous version with no problem.
My files are stored on an external drive with the catalogue on the laptops HDD as I have always worked this way in previous versions.
Just Checked and its not applying the denoise to the tiff either it seems to be just sending the original back to LRC without actually doing anything.
Please open Topaz Photo AI, go to the menu bar on the top and click the Help > Open Log Folder menu option. Upload the log files to this thread or to my Dropbox link below. Please be sure to send me a note to let me know you sent something.
Dropbox File Request
