Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
My apologies for missing your response on this thread. Are you able to send in the system profile information to the Dropbox link in the comments above?
Did you send the system profile via the Dropbox link above? I do not see the information in my Dropbox folder and it does not appear the system profile information attached to this forum thread.
