When going from Photoshop to Topaz Studio and then opening AI Clear nothing happens. My image is not sharpened or is there noise reduction. I thought it was automatic when opening an image. Need help. Thanks.
Hi Sanford
There are sliders that you can adjust to set your image up as you like it. It cannot be automatic as AI Clear can only adjust automatically as a first setting. It is then up to you to tweak the settings according to your individual photos. Not all images are alike, so it would be impossible for it to be automatic. Hope this helps.
When I use AI Clear in Studio, it will automatically denoise the picture preview since it defaults to Auto. When saving, it must process the whole picture so it still takes time.
