Just updated the Ai Photo software to the new AI.3.1.0 version, attempted a scan, each time it’s starts scanning, selects DeNoise then closes completely.
DxDiag.txt (89.4 KB)
mike klein[date=2024-07-12 timezone=“Europe/London”]
Thanks for sending in that information.
I want to see if updating your GPU driver will resolve the problem, as there is a more up-to-date driver that has been released.
Please use the following link to update your driver: NVIDIA | Quadro K4000 | Driver Update
Thank you, just checked I have k5000 installed, just opened and checked. physical hardware. Will go to driver update.
Installed latest drivers, re-booted, same problem.
Please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
Hi John
Hopefully this is the data you’re looking for.
mike
lastSessionFiles.txt (33 Bytes)
2024-07-12-18-43-29.tzlog (15.9 KB)
2024-07-12-16-57-12.tzlog (47.9 KB)
2024-07-12-17-11-39.tzlog (16 KB)
2024-07-12-16-52-23.tzlog (47.9 KB)
2024-07-12-18-45-21.tzlog (47.8 KB)
2024-07-12-18-51-57.tzlog (47.8 KB)
2024-07-12-19-14-23.tzlog (31.9 KB)
2024-07-12-19-14-48.tzlog (47.9 KB)
2024-07-12-18-48-13.tzlog (191 KB)
2024-07-12-19-18-0.tzlog (47.8 KB)
2024-07-12-19-18-48.tzlog (15.9 KB)
Topaz Photo AI Installer Log.txt (4.67 MB)
I’d like to see if adjusting your AI Processor will help with the problems you are having, please open Topaz Photo AI and go to Preferences > General and set the AI Processor to GPU.
Run some test and let me know how that goes for you.
Hi John, you should not be working today, you need to rest for the big match tomorrow.
Thank you for your support much appreciated.
Last night I didn’t sleep to well brain was working overtime but I did change Ai to GPU and yes it’s working.
John again Thank You, you software is just
Kind Regards
Mike Klein
Why does Topaz introduce updates that fail to work?
I hesitate to update every time due to issues, just when the program is doing a good job and you have a handle on its operation Topaz changes everything and it runs so slow you don’t even want to use it!
I would suggest that Topaz not introduce an update until it has been tested and works properly!
