After Effects plugin causes excessive video levels in 16bit project
When using the After Effects plugin in a 16-bit project the rendered result is massively over-bright. The viewport window looks correct but the live output to video monitor via a Blackmagic Intensity Pro is over-bright and clipped. The rendered output matches the video output. 8-bit projects appear to be OK.
DxDiag.txt (118.7 KB)
