Was wondering if I already have the topaz and some pro adjustments and and plugins is it worth the money to get the lab also? Thanks for all who answer. Toni
fxLab is showing its age - only get fxLab if you have a low spec computer - you will also have to d/load the Legacy versions of the plugins as well.
Try using Topaz Studio, the Basic Adjustments are also free and it will also all your existing plugins.
