The adjustment panel that ran along the right side of the photo from top to bottom is missing after running update. What happened to it?
At the risk of stating the obvious and hoping to not offend, have you checked your startup options under preferences?
Thanks, I will check it out. I think I looked at the preferences when I was looking for a way to get them back. I will check it out and see if I can see it.
Yes it is. Thank you
