Adjust Lighting Issue
[Please describe your issue here. Try to include logs (Help → Logging) and add screenshots if necessary.] The topaz program cashes when I run the adjust lighting filter on all types of image files
Steps to reproduce issue:
  1. Step 1 Running the adjust lighting filter since the last update
  2. Step 2
  3. Step 3
Topaz Labs | Support Page
