I’m trialing Adjust AI and right away I noticed something unusual. When I click on the scroll bar to the right of the presets, it highlights when I click on it, but I cannot drag it at all. When I switch to another running app, no problem, things scroll there fine. But switch back to Adjust AI and I can’t get to the bottom of the presets list.
I don’t use a mouse, but a Wacom Intuos tablet. I’m running the Mac version (High Sierra, 10.13.5) on a 27 inch iMac.
Maybe because I have an older Wacom (Intuos 3), but the only thing related to Windows Mapping in the Tablet Properties are a series of drop-downs setting the orientation, screen areas, and tablet areas. There’s no ‘Mapping to Windows Ink’ to be found.
This is the properties window for the Windows PC version of the Wacom pen. The problem exists on a MAC, which does not have a Use Windows Ink check box inside the Wacom Preferences.
I too use an Intous 3, though I haven’t tried this - in Wacom Properties Add the Topaz programs to Functions Tab Applications and review Touch Strip settings- worth a try. To note my Wacom works on scrollbar if clicked on right, if pointer on image it zooms.
