I access Topaz Denoise and Sharpen from Lightroom Classic. LrC is limited in it’s file naming so all external editors use the same filename suffix which in my case is ‘-edit’. I don’t see any changes to the metadata based in the features I’ve used in a metadata tool e.g. ‘low light’. Is there someway to have Topaz products write to the TIFF file past back to LrC some high level indication of what was applied? Perhaps a custom Metadata section? Something similar to the notation at the bottom of the Topaz screen when the changes are being applied
Thanks
