Add removal of dust and scratches
Many scanners have IR and normal light. The IR allows for dust to be isolated from the rest of the image as a mask. It would be amazing if you used this to train a dust and scratches model that actually worked to fix film scans. That alone would get you the entire film community. All older dust removal algorithms are garbage and I have tried most of them.
Also, bonus points for accepting tiffs that have the dust mask and actually using that as well. Probably not necessary but would be amazing.
3 posts were merged into an existing topic: [DUST & SCRATCHES] - Add AI dust spot/ scratch removal
3 votes have been moved. A vote could not be moved because the user already voted in the other topic.
