Add Noise Reduction Settings to the Autopilot
Sometimes when you want to process a large batch of very similar files and the analysed noise reduction is too aggressive (or is off), it would be great to have the ability to set the level of default noise reduction (i.e. fix the level or turn off) for the autopilot without having to go to every photo to choose the noise reduction setting you want before processing. Not sure why it’s not included as all other features appear to be settable in the autopilot - maybe there is technical reason.
