Add alpha transparency sliders to all effects
The slider setting of each effects doesn’t behave as “normal”, and this is confusing. “Normal”, refers to Lightroom or other editing software, where those sliders are kind of the strength of the effect thru an alpha mask, a kind of transparency application.
On Photo AI, its different, it modifies what the AI actually creates, it’s kind of put more ai into this, like think harder. The results are different than just stronger.
Often, using sharpening if the slider is below a certain % it won’t pick a particular feature, that it would pick at stronger settings, however doing so it is too agressive on that feature.
So a transparency setting would help, or a morph one.
That will really allow us to adjust the look of the final image.
