Add a focus track point for the stabilizer option
You should add this as a feature where you can select a point in either a dark or light scene and choose an object for the AI to focus on, then stabilize the scene based on the selected object. I’m not sure if this was an idea someone else has brought up, but it would be extremely helpful for scenes where the camera person is recording from a single spot. It would be like a proshot of some sort.
Example: You are recording a special effects show, but you are moving too much and wish to keep the camera specifically pointed in one direction. The other issue, despite the camera being stabilized, you are slowly drifting off towards one direction. This is where the focus track option comes into play. You either select, possibly, one of the speakers on the stage, or some conspicuous object for the AI to use to help fully stabilize the shot.
