Add a 2nd Mask in Texture Effects
Is there a way to add a second mask on an effect in Texture Effects. In other words, if I create a mask with say the spot feature, can I then add another mask on that same effect with say the brush feature or is only one mask possible?
No there isn’t. Note I have removed this from the Product Feature Request section as it is no longer supported.
