It’s a bit difficult to determine if you are trying to install your version of Topaz Photo AI 4.0.3 on a newly purchased computer or you have uninstalled Topaz Photo from your new computer and you are trying to re-install it again on the same computer as you mentioned “I re-installed Topaz 4.0.3 on a new computer”
If you have indeed installed Topaz Photo AI on a new computer and it’s defaulting to Trial Mode, it usually comes down to one of three specific causes:
1. Version vs. License Expiration Mismatch:
Check the version number installed against your account on TopazLabs.com. If your updates/upgrade license expired prior to the release of version 4.0.3, the software will drop into Trial Mode even if you log in correctly.
Fix:
Log into your Topaz account on the website, go to My Products, and download the specific final version tied to your license seat.
2. In-App Login Loop / VPN or Add Blocker:
Sometimes the browser-based authorization fails to pass back to the app on a fresh OS install.
Fix:
Log out inside the app, close it, temporarily disable any strict antivirus/firewall or browser ad-blockers, then open the app and log in again.
3. Wrong Account Credentials:
Ensure the account email logged into inside the app matches the exact email address used to purchase the license.
Hi,
I downloaded 4.0.3 from the website as my computer totalled and I don’t
have the original version. From the looks at my acount a see a date of
july 12th 2024 for my renewal. That is about the last I can see. I do
not see any versions available before 4.9 si I don’t know how ta handle
this. My opinion was bought and own.
Regards,JDE
