Ability to nudge image when using "crop to fill" setting
Example:
Upscale a 720x576 video to Full HD. When “crop to fill” is selected in the crop setting, the video of course crops to fill. But usually this means that a bit too much of the upper part of the screen is cut off. This can easily be fixed if you were able to nudge the video around with a four direction arrow tool for instance.
