… or can’t I find it ?
I need to save
- the settings (ok, is there)
- the input file (name and location)
- the crop settings (!!!)
- the trim settings
oh, a window popped up, that shows, I’m not the ony one…
Anything in progress ??
// Harry
I need to save
// Harry
That means you should look at it, to see if someone has already made the post you’re about to make. Then you can add your thoughts to it.
Not dedicated to the idea, but mentions it from Feb 2022.
From August 2022
From January 1st
