I’ve determined that Rhea XL creates sharp edges but introduces a grid artifact in 3D renders because it’s weak to subtle gradients. Use it for great results with 2D renders.
Rhea does not have any grid artifacts, and while it’s a little less sharp, it handles 3D subtleties very well. Use it for great results with 3D renders.
Mind these notes for maximum possible quality if you like to double your resolution with Starlight, then use another model to bring the result to a final resolution, possibly also using frame interpolation.
