Nicely done Sharon …
Nice one. I like the sharp droplet against the diffuse background.
I would try to eliminate the chromatic aberration. Depending on what tools you have, you might be able to remove all of it. LR does reasonably well at it, though you’d need to manually adjust it due having multiple hues of fringing.
Best regards
