I really like A.I Clear… would love to see the ability to use the batch process with A.I Clear…I get lots of images from different sources which in most cases have lots of noise… Would love to push a button and process all the images in one shot…
In Topaz Studio you can batch-process using AIclear.
Just load an image (just 1, not the entire batch), set up your processing-chain (which would be AIclear in this case), then go to the top-left menu ‘batch process’ and use that (this is where you choose the folder that has all the images you want to batch-process)
Runs like a charm
