A couple of ideas that may help
#1 Add ALWAYS ENABLE to both Remove Noise and Sharpen
#2 Add multiple Named Saved Preferences including a Default for Autopilot. This would work if it could be used for multiple uses of the plugin in a session where you opened and set the Named setting then used it using the plugin.
#3 Add Keyword for each action of autopilot to Mac Photos plugin. Would be nice
Never been so happy with an app for my Mac. Had a Mac since 1985 and used the Lisa before that.
Thank you for a great product
