The export seems to always be 16 bit color.
Can I set the preference to 8 bit?
I do not see where I can do this.
Am I best off accepting your 16 bit and changing it to 8 bit in Photoshop?
I have been using your stand alone - perhaps doing it in the Photoshop plug-in will make my workflow easier if I need to do this.
I print images via inDesign
- one image goes in straight as your tif
- one image is placed in Illustrator for a label
Adobe Illustrator does not accept 16 so will reinterpret to 8 bit
(I am always leery of auto changes inside a program that was not built for dealing with pixels – the teams inside Adobe do not seem to cross pollenate their products with the same thing they all seem to build their own)
