I’ve notice the blur type square block artifacts on complex backgrounds, leaves, fences ect is not bad on 720p, but the exact same scenes at 1080p have these artifacts. This is purely the exact same scenes at both resolutions tested in multiple movies. Big difference. Less artifacts at 720p. No other processing done. Downscale to 720p from 1080p was done in handbrake before running topaz on it.
Hi, I’m Not using slo mo. Just fps increase for movies I have on blu ray.
Texas chainsaw massacre, As Alexandra daddario is waking across a deck with a waist high fence in front, It’s blurring the fence. Not even a fast pan. Just walking. Time stamp is 25:15. This is seen on 720p and 1080p, but NOT 480p. The lower resolutions have less issues. This makes no sense. I’m not interested in upscaling back to 1080p after downscaling to 480p. It wont’ look as good as native higher resolution and it’s a waste of time.
This is something that needs work. Apollo doesn’t do this, but apollo has other issues and It’s not as natural as chronos.
In Cursed, Christine Ricci, at 22:50 to 23:00 this background wallpaper is getting a blur without even any panning at 1080p, but not 720p.
I’m sure your technical team is fully aware of these kind of artifacts. I can take the time to upload pictures if you need to, but I’m sure you’re fully aware of this limitation. For some reason it’s worse in certain scenes like one above at 1080p. That checkerboard wallpaper pattern was causing this pulsating blur.
And I should also mention that downscaling to just under 720p, like 1042 from 1200 caused the blur to go away as well on texas chainsaw scene. It’s clearly having issues with higher resolutions. It can’t handle the calculations properly, which shouldn’t be an issue since processing time is increasing giving it more time with higher resolutions.
I realized the lower resolution just gives different artifacts in different scenes. It’s clearly just a limitation of the model. Chronos is still the best by far. I just wish they could fix some of these artifacts around fences and other complex geometry/ This wobbling type of blur.
I’ve tested this extensively. Lower resolutions have less artifacts for sure. I’ve tested over 30 scenes.
I have tested a ton of movies with chronos/apollo. A resolution of 960x540 has less artifacts than 720p, which has less artifacts than 1080p.
At 960x540 with apollo 25 to 50fps, then chronos 50 to 100fps there are almost no artifacts at all and I’m looking very closely at specific scenes with difficult geometry.
Unfortunately this resolution looks terrible on a 75 inch and upscaling after the fact doesn’t make it look as good as the original 1080p source that it was downscaled from.
720p seems to be the sweet spot. 1080p chronos alone without apollo first, is really unusable due to the amount of artifacts. THere are these tile like square blocks of blur. Even someone’s shirt that has a complex pattern on it can cause it or windows Blinds in the background. A quick pan in a grocery store with a bunch of stuff on the shelves. Also, scenes with fences are notorious for this.
I’ve even seen bushes/trees in background cause it!
It would be nice if we could just use chronos with it’s natural motion with one pass and at full 1080
But right now I’d recommend downscale your video to 720p/540p and then use apollo 2xfps, followed by chronos. Only reason to use apollo first is because chronos still has artifacts even at lower resolutions! Less, but still too much. The combo lets chronos give smooth motion
Also, I would not go below 720p because the frame interpolation REDUCES quality a little bit from native source. I’ve tested this out. It removes grain(which i don’t mind), but it also reduces quality. I’ve seen text on n a sign in movies become less clear. Obivously a little reduction in quality is more noticeable at lower resolutions . So, 720p is absolute minimum. I’d like to see some improvements to chronos in the future.
Also, doing the 2 pass second step isn’t really 100 percent necessary. If you’re at 100fps, apollo loses most of it’s jitters/speed up effect that is has at lower fps. You can just go 4x fps 25fps to 100fps for apollo and skip the second chronos. At lower fps, apollo is very jittery though, but once you get to 100 I think also those extra frames helps mask it. It cuts the encode time in half doing that. I checked a couple of scenes and didn’t notice a difference 2 pass and 1 pass once it was at 100 fps. VERY noticeable difference between chronos and apollo at 50fps. Apollo is jittery and very unnatural at lower fps, but at 100 fps I couldn’t see a difference between the 2 pass with apollo then chronos vs 1 pass apollo to 100fps
