7.0.5 very compressed better
I used to find low resolution mode best for improving images from web pages, but with the latest release, I find very compressed is usually giving better results. The PNG file sizes are huge though, and it still has problems with people’s facial features, lips in particular. Surprisingly, CGI mode often gets faces better than the others. (I have examples I can upload when there’s a facility for that.)
face
face-topaz-high-compression-4x
Have you tried using the Face Recovery tool when the models are struggling to enhance the face?
Yes, and it helps a lot. I deleted the post that reported results before I found the switch to turn it on.
Oh, perfect! Are you still running into problems even with that on?
