Good morning.
I am asking if it is possible and how to save the various settings in the Enhancement section.
Thank you
You can create presets! Select your settings then locate the preset filter at the top right-hand corner of the app, click the … and create new preset.
for more info visit our docs page
Thank you for your response.
I ask if it is possible to export the saved preset.
I’m afraid Topaz don’t make it that easy. The list of all preset names, including any of your own, are stored separately from the individual files that contain the preset’s settings. You could manually copy out any of your own preset definition files to another location for “backup” if you wanted. However, any backed-up files aren’t as useful as they could be, because there is no way to directly import them to TVAI.
Anyway, in Windows, they are stored as json files in:
C:\ProgramData\Topaz Labs LLC\Topaz Video AI\presets
On Mac, they are stored within the application’s own folder:
/Applications/Topaz Video AI.app/Contents/Resources/presets
Andy
