5.1.1 Iris MQ 720p -> 2160p out-of-memory
Upscaling some episodes from a 720p series to 4K using Iris MQ model, worked fine with previous version (not sure what the exact version was but I reported today 2 updates available)… Now (with 5.1.1) it stops after ± 1 min and reports Out-of-Memory.
Running on a M1 MacBook Pro with 16GB RAM.
Can you open up a support ticket with the apps logs and your system profile at help@topazlabs.com
  1. To gather logs, please select Help > Logging > Get Logs for Support and attach the zip file to your reply.
  2. How To Obtain Your System Profile (Mac)
