TVAI version: 4.0 on macOS
Description of issue:
When generating some previews with similar, but not the same settings as a preview preview, some of the previews will be grouped together with other previews, while also introducing UI issues.
Steps to reproduce:
- Import a video.
- On side 1, set Enhancement to Nyx (Or some other model)
- On side 2, set Enhancement to Gaia (Or some other model)
- Generate a preview. And wait for it to finish.
- Select the Crop setting and crop your video.
- Generate a new preview
- In the Previews section at the bottom, a second Gaia will be added (because the settings are different from the first one due to the crop). However, Nyx doesn’t get a second preview.
- Notice how on Side 1, it says the preview is Nyx. But notice that in the “Previews” section at the bottom of the app, apparently Side 1 is “Original Video”.
Here’s a video showing the issue:
Note: Crop doesn’t work in preview mode, see 4.0 Crop doesn't work in preview
