Hi,
If you try to preview a frame with the 0.1 second setting, it will never start the step after “model loaded”. I attempted this even after uninstall/reinstall on 3.1 . 1 second preview works fine. The whole program just stops working. It even pauses the queue if you are on 2 processes and will not let another start.
I thought at first my entire program was broken but it turns out that was the issue. In case anyone else stumbles onto this.
Love the program otherwise, Thanks
