I recently started using Photo AI 3.4.3 in a Windows 11 Pro computer fully up to date with two ASUS ProArt monitors. One monitor is 24 inches and the other is 27 inches.
Photo AI loads and works fine on the 24-inch monitor, but it freezes while loading on the 27-inch monitor. Other software, such as Lightroom Classic and Photoshop, works fine on the larger monitor. I ran a repair but have not completely removed and reinstalled the software.
Has anyone experienced this behavior? If so, did you find a solution?
I will greatly appreciate your response.
Mike.
IF YOU HAVE AN ISSUE:
- Make sure you check this post first:
====>> [CHECK THIS FIRST] 🚨- How to report a bug or issue for Photo AI - #3 - The fastest way to reach us is to send us an email at help@topazlabs.com
TO CREATE A FORUM TOPIC
- Give as many details as you can on the issue you are experimenting.
- Workflow steps you do, if using the standalone or plugin. File Type used is RAW or JPEG?*
