2.0 Installation taking foooorrreeeevvvverrrrr!
On Friday, I downloaded and started to install the version 2.0 update on my M1 MBP running Monterey 12.6.8. It was taking a long time, so I left it to run over the weekend. Monday morning and it is only halfway done. Not sure what is going on and I don’t want to stop it at this point since it is progressing.
Can anybody able to tell me what’s going on and how to resolve it?
Topaz Photo AI [v2.0] on [Mac]
Installer Log 11-Sep-2023.txt (235.0 KB)
Thanks for reaching out. It looks like the download is getting blocked for some reason.
First, please disable antivirus, firewall, VPN, or proxy that may be on your computer. These are known to block the installer from downloading the model files.
Then try running the installer again. Let me know what happens after you do this.
