After downloading 2.0.1 version, enhancement viewing of the side-by-side or any view seems to be stuck in a very magnified view, To the point that I cannot view the changes.
Example would be let’s say the side-by-side view. I set the image size to view the whole photo, but the enhanced side only shows a very zoomed in picture.
Please take a screen recording of this behavior so I can see exactly what is happening. Loom is a great free application for this: Download the Loom Desktop App | Loom
What is the starting file type you are using? Is it DNG, Raw, or non-Raw?
This is a known issue with some DNG files and lens correction.
To fix this, open Topaz Photo AI and go to the Preferences menu > General tab. Disable lens correction and the file should no longer have this problem.
Please send me the image so I can make note of this for my team to fix. You can securely submit your image(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something. Dropbox File Request
