1.7.0 Multitabs setting bug
Win11
Next to the card with the SLP 2.6 setting, I added two other cards to test a few seconds of the film. I set the second one to Gaia 2, and the third one I tested other models. All of them required x2 output resolution.
When, after creating these two new test cards for 5 seconds, I clicked once on one card, then on the other, I suddenly noticed that the second card, instead of the Gaia 2 model, has the model from the third card (Proteus) set, but without the Proteus parameters. When I looked at the first card, there was still SPL, but not x2 FHD, but the minimum 720. After returning to the second card, I also had 540p sources instead of FHD.
Well, that’s no way to work, gentlemen and ladies of Topaz.
Would you be able to share a screen recording of the behavior?
  • We recommend loom, it’s free and easy to use. Once your Loom recording is ready, you’ll be able to get a link with the video, please reply back with the link
  • Feel free to use any other preferred method and send the video file attached to your email replace. If the file is too large to attach, you can upload it here: Submit File to Dropbox
The video has been uploaded to Dropbox.
