I have exact the same issue with 1.7.0 as with 1.6.1. that I have reported already several times. See as follows “Since 1.6.1. each video rendered with Starlight Presision causing a rendering pause like every 1/3 of the video. This rendering pause vary from 5 - 30 minutes. Then the rendering continues out of nowhere… This happens several times when rendering longer videos causing way longer total rendering times. 2h total waiting time for 15-20 seconds videos is now the new norm. This issue has become persistant since the latest patch 1.6.1… Please help.”
I am really dissappointed that you have not fixed this after several month. Your latest version consequently remain unusable for me and I will stick with 1.6.0 until further notice…
Hello,
We requested the app’s logs from your post in 1.6.1 but did not receive them to investigate this issue. Could you share those with us?
To gather logs, please open the app and select Help > Logging > Get Logs for Support and attach the zip file to your reply.
help@topazlabs.com
2026-08-13-02-22-48-Main.tzlog (306.1 KB) please check if you can work with this. This is the latest log after the process has been pausing again for at least one hour…
Looking at what was captured, the process started at 2:23 and frames were actively processing, the logs were then pulled at 2:31, just 8 minutes into the export. Unfortunately this means the log doesn’t capture one of the pauses you’re describing, so there isn’t enough data here for the team to investigate the cause.
As said, if you are not able to fix I am happy to stay with 1.6.0 that I am now using again without any issues. Will save me some money in the future…
